How do I remove the oil pan on a 1998 buick lesabre. Do I have to lower the pan a little and remove the pick up tube then pull the pan off completely? Is the oil pump located inside the oil pan or on the side of the engine accessed from the wheel well? do you reccommend packing the oil pump with grease when replacing?
May 9, 2010 at 6:23 AM
