1997 Buick Lesabre
1997 BUICK LESABRE
50,000 MILES • 6 CYL • FWD • AUTOMATIC
ROBERTBLACKWELL
Suddenly, after repairing heater & AC air distribution system, the curdesy lights in doors and under dash stopped working. All fuses checked good. the dome light also stopped working. When I slide the interior light switch to on, the lights still will not come on.
Jun 20, 2009 at 2:31 PM
MERLIN2021
  • 17,250 POSTS
If you did the work, did you remove ANY ground wires from the body or supports? or unplug any connector and maybe not get it pushed together tight enough? Usually there are ground straps and modules in the way, either under the hood or dash...recheck all! BTW, do all controls for heat and a/c work now? Thje BCM is on the right side of the car, and needs to be removed from the bracket. Put it all back together? ALCM is near the right of steering column, is it back there?
Jun 20, 2009 at 7:24 PM
