Disconnect negative battery cable.
Raise and support vehicle. As required, remove nuts from A/C compressor, exhaust system and/or engine braces, adjacent to starter.
Remove other items that may interfere with removal of starter.
If necessary, remove nut from engine cross brace. Using pry bar between upper engine mount and engine, pry rearward and support engine.
If necessary, remove oil filter, air induction tube and cooling fan.
Disconnect wiring at starter, and note position.
Remove starter mounting bolts and any shims.
Remove starter.
Installation
Before installation, ensure pinion-to-flywheel clearance is .020" (0.5 mm).
Add or subtract shims as necessary.
To complete installation, reverse removal procedure.
Tighten mounting bolts
Nov 18, 2020 at 8:18 AM
(Merged)
