1995 Buick Lesabre R & R'D ENGINE
1995 BUICK LESABRE
90,000 MILES • 6 CYL • FWD • AUTOMATIC
JIMMIEDEE
EVERYTHING IS BACK TOGETHER BUT THE FUEL PUMP DOESN'T COME ON AND IT WORKED BEFORE R &R'D ENGINE. CHECKED THE INERTIA SWITCH IN TRUNK, ITS GOOD. CAN'T HEAR THE FUEL PUMP RELAY CLICK EITHER.
Feb 22, 2010 at 12:32 PM
Hi jimmiedee, Welcome to 2carpros and TY for the donation
Check and test fuse no.6 20amp in relay center right side of instrument panel top of shroud. Make sure the oil pressure switch is firmly connected-and test the fuel pump relay
BTW do you hear the fuel pump come for 2secs when key at run position if not do above if so check the fuel pressure-let me know
Feb 23, 2010 at 3:12 AM
