1995 Buick Lesabre how much to fix the fron transmission se
1995 BUICK LESABRE
JAMIELEE13
Transmission problem
1995 Buick Lesabre 6 cyl Automatic 164000 miles
the seal is what connects the engine block and the transmission.
Nov 11, 2008 at 6:49 AM
Hi:
The engine and transmission are bolted together. There is a front seal on the transmission. Is that what you're refering to? If so, the part is cheap but the job is labor intensive. The trans needs to be removed. I looked up the labor rate and it allows 6 hours for R&R. The seal should be under 20 dollars.
Let me know if you have any other questions.
Positive feedback is appreciated.
Nov 15, 2008 at 8:47 PM
