1995 Buick Lesabre computer problems
1995 BUICK LESABRE
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADAMKING18
The hot light and charge light flash on and off after driving for a good amount of time also the check engine light comes on, then the car starts to shake and wants to cut off and then it will cut off. but i can start it right up again. Is this a computer problem or is it the module? or something completely different.
Jan 8, 2009 at 9:00 PM
BMRFIXIT
  • 19,053 POSTS
I would check the belt
water pump,coolant ....
and make sure engine is not running hot at 1st
computer will not turn hot light on
Jan 9, 2009 at 6:33 AM
ADAMKING18
[quote:2fee59ddba="BMRFIXIT"]I would check the belt
computer will not turn hot light on[/quote:2fee59ddba]
The car does not seem to be over-heating and the hot light is not the only light to come on. Do you think it could have anything to do with the module?
Jan 9, 2009 at 1:38 PM
BMRFIXIT
  • 19,053 POSTS
Module NO
suspect electric problem and or loose ground
Jan 9, 2009 at 7:19 PM
