1994 Buick Lesabre Fuel Pump Fuse
1994 BUICK LESABRE
BKMATTHEWS
  • 10 POSTS
Electrical problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic
The 20amp fuel pump fuse keeps blowing. I have replaced the relay checked the oil pressure sensor and the fuel pump is less than a year old. Previously replacing the relay fixed the problem. I have tried starting the car with each of the parts unplugged and the fuse still blows. Any ideas?
Jun 24, 2009 at 12:58 PM
JDL
  • 16,098 POSTS
Did you try unplugging B+ at the ignition module? How long since a tune-up?
Jun 24, 2009 at 1:16 PM
BKMATTHEWS
  • 10 POSTS
unplugged alternator, checked injector wires......what is B+?
Jun 24, 2009 at 1:37 PM
BKMATTHEWS
  • 10 POSTS
new wires 1 yr ago. i think new ignition module at the same time....is that where the spark plug wires run?
Jun 24, 2009 at 1:41 PM
BKMATTHEWS
  • 10 POSTS
unplugged a+ b- c at ignition, also unplugged sensor at air intake that leads to fuel injectors....still blows fuse.
new coil packs 1 yr ago
didnt unplug coil yet.
Jun 24, 2009 at 3:37 PM
JDL
  • 16,098 POSTS
B+ is just battery voltage. the ignition module sits under the coil pack, where the plug wires go. The pink wire, carries B+ to the module. The circuit goes hot with the key on. Also, the cam and crank sensor shows to be hall switches, they get feed from the ignition module, something else to unplug. Did you unplug the pink wire at the module?
Jun 24, 2009 at 3:55 PM
BKMATTHEWS
  • 10 POSTS
With ignition module unplugged and relay out the fuse doesnt blow. As soon as i plug in module and turn key the fuse blows. What are the gray relays under the main fuses on the firewall under the hood. It looks like 2 pink 1 gr 1 gr+w 1 gry 1 blk and 2 or enter the leftmost relay(passenger side)
Jun 27, 2009 at 7:48 PM
JDL
  • 16,098 POSTS
The relay to the passenger side should be the blower motor relay, next, ac compressor relay-- cooling fan relay low speed-- cooling fan relay high speed.
Jun 28, 2009 at 11:32 AM
BKMATTHEWS
  • 10 POSTS
Still having the problem........
I have unplugged everything connected to the relay.....PCM, fuel pump, oil pressure sender and ignition control module...... when I plug in the computer the fuse blows.....
Does the computer supply power to the relay through the grn/white wire?
Jul 1, 2009 at 4:37 PM
BKMATTHEWS
  • 10 POSTS
grn and wht runs from PCM to relay
Jul 1, 2009 at 4:39 PM
BKMATTHEWS
  • 10 POSTS
Its either that or the gry that goes to the fuel pump and oil pressure sender
Jul 1, 2009 at 4:40 PM
JDL
  • 16,098 POSTS
the voltage for the coil side of relay comes from the pcm, green/white wire.
Jul 2, 2009 at 8:39 AM
BKMATTHEWS
  • 10 POSTS
does that mean the problem is between the relay and the coil????? what do i need to check? the fuse blows when i unplug the ignition control module.
Thanks for the help
Jul 2, 2009 at 9:28 AM
BKMATTHEWS
  • 10 POSTS
If the fuse still blows with the icm unplugged its got to be a wire, doesnt it?
Jul 2, 2009 at 10:20 AM
JDL
  • 16,098 POSTS
Have you tried using the prime connector to run the pump? The prime connector should be behind the battery or close, red wire, has a connector, nothing plugged into it. If you use a jumper coming off battery voltage with an inline fuse, touch the connector, you don't have to use the key, the pump should run. At least maybe you can rule out that circuit?
Any circuit that you think may have a short in the wiring, make sure the wire is unplugged at both ends and that the circuit is isolated from any other circuit, use a testlite, one end of the lite connected to B+, touch the other end to the wire, if the lite comes, it's going to ground somewhere, you'll have to find it.
Jul 2, 2009 at 11:24 AM
