1994 Buick Lesabre Electrical / weak spark problem
1994 BUICK LESABRE
OLDTIMER10
  • 4 POSTS
Electrical problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic 175k miles
Spark plugs (new) show weak, arching, yellowish spark. Not a sharp, blue snap as normal.
Tested wires, ICM, coils, crank sensor etc.
Unplugged PCM connector & checked with test light from BAT+ to the PCM connector Pins # B11,B12,B13,&B14.The test light lit bright on each.
Checked with voltmeter from Pins #WC7,WC8,&WC9 to ground and have 11.5V
From whence does this failure come?
Nov 9, 2008 at 11:33 PM
What was the coil primary and secondary windings resistances-what is the voltage on the coil's positive terminal when key at run position
Nov 9, 2008 at 11:58 PM
OLDTIMER10
  • 4 POSTS
Primary side is zero Ohms with continuity. Secondary's are within range.
Nov 10, 2008 at 12:10 AM
Do you have an HEI distributor or DIS See below info and also check the distributor pick-up coil
https://www.2carpros.com/forum/automotive_pictures/12900_d1_3.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_d2_3.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_d3_1.jpg
Nov 10, 2008 at 12:25 AM
OLDTIMER10
  • 4 POSTS
I believe it is a DIS waste spark system.
Coils have been load tested independent of engine with same weak spark. Also tested new coils with same weak spark. I believe I have a grounding problem. Can you tell me the locations of ground straps from engine to body?
thanks
Nov 10, 2008 at 10:48 AM
Check ground point G120 above the AC compressor
https://www.2carpros.com/forum/automotive_pictures/12900_pcm_ground_1.jpg
Nov 10, 2008 at 2:01 PM
OLDTIMER10
  • 4 POSTS
Removed wires, cleaned and applied dielectric grease at G120.
Also, checked b11-b14 with multimeter which check ok.
Thank you
Nov 10, 2008 at 2:10 PM
