1994 Buick Lesabre
1994 BUICK LESABRE
BROWNEYES52701
Engine Mechanical problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic
the car wont stay running longer than 3 seconds unless starting fluid is continuosly sprayed in the throttle body. i have changed the fuel filter,pump.what is the problem
Oct 10, 2009 at 6:22 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Have you check the fuel pressure and the fuel pressure regulator.
It is possibly the fuel pressure regulator. If you have a fuel pressure tester or can rent one here is a link to a video explaining the test proceedure.
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Oct 10, 2009 at 6:44 PM
