[quote:e5cbd13752="Gomez1976"]Air Conditioning problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic 93,000 miles
my a/c is not coming out of the vents no matter what button i push. Instead, it flows out at my feet like the heater would. How do i fix this?[/quote:e5cbd13752]
Yes sir you have a problem with your vacuum lines, on bottom of the dash on the passengerside you will have to remove a panel on the bottom to access them you can either test is or clip the pink line and plug into the blue port on the ac (will always blow toward you) otherwise check your harness to makesure all connections are tight and that your switching block is working if you need morehelp feel free to contact me at admin at whypayforhelp .d. org
Jul 22, 2008 at 4:05 PM
