1992 Buick Lesabre NO Pressure in Brake Pedal
1992 BUICK LESABRE
187,000 MILES • 6 CYL • FWD • AUTOMATIC
MICHELLEPRESSLEY
I have no pressure in my brake pedal. I had my brakes blead in the front only. I don't hear any grinding in the pads and there is no leak in the master cylinder. I hear I need a brake booter. Does that sound accurate?
Jan 25, 2010 at 1:24 PM
HMAC300
  • 48,601 POSTS
you should bleed the whole system first before replacing the booster. As you may have air in the back of the system. Boosters do go bad occasionally but it usually leaves a very hard pedal. Check your booster valve on the booster itself. that does it sometimes as well.
Jan 27, 2010 at 5:40 PM
