we cant get the harmonic balancer bolt out to repair front main seal leak
May 6, 2008 at 9:10 PM
CERTIFIED EXPERT
Either you drop the starter and jam the flexplate or use a long breaker bar brace it properly underneath-clear out of the way and crank engine over this will loosen it-or you can try an impact wrench-
May 7, 2008 at 4:41 PM
BUZZSAW
CERTIFIED EXPERT
[quote:83a139e216="rasmataz"]Either you drop the starter and jam the flexplate or use a long breaker bar brace it properly underneath-clear out of the way and crank engine over this will loosen it-or you can try an impact wrench-[/quote:83a139e216]
