1991 Buick Lesabre windows
1991 BUICK LESABRE
FRIARDAVE
1991 Buick Lesabre
Hi...i can operate the rear windows with the master switch but not the front windows...also the front passenger window switch is inop...where should i look?...thanks, dave
Apr 14, 2009 at 6:39 AM
JOLENA2370
  • 14 POSTS
Have you pulled out your switch yet if you have have you tested for power at the switch with a test light or a voltmeter? I think that you should pull that drivers side control panel out and test that if there is power then check your regulator down at the bottom of the door e-mail me and let me know if there is power or not I will be glad to walk you through this problem.
May 6, 2009 at 1:00 AM
FRIARDAVE
Jolena2370...yes there is power at the switch
May 6, 2009 at 7:35 AM
JOLENA2370
  • 14 POSTS
Do you know how to pull the door panel off? If you do check and see if there is power at the regulator if there is then the regulator is bad and needs to be replaced!
May 9, 2009 at 2:09 AM
