1991 Buick Lesabre Multiple lights, gauges, and heating pro
1991 BUICK LESABRE
3,000 MILES • 6 CYL • FWD • AUTOMATIC
CHARLIE'S MOM
Could corroded positive battery cables be related to any of these problems? I recently replaced the stripped terminal post bolt when it wouldn't start and that solved the starting problem, but it appeared that there was corrosion on the cables. Should I start with replacing those before taking it into a shop?
Jan 22, 2009 at 12:23 PM
JDL
  • 16,098 POSTS
I'd clean the battery cables/wires on both ends, make sure everything is clean and tight. You might peal the insulation back a bit on the cable/s, see if there is any corrosion, if there is, replace the cables.
Sometimes with multiple electrical problems, if you trouble-shoot one circuit and fix, it may fix several other problems.
Jan 23, 2009 at 8:53 AM
