1991 Buick Lesabre Continuous Jump Start Needed
1991 BUICK LESABRE
ALOHRMANN
Electrical problem
1991 Buick Lesabre Front Wheel Drive Automatic
2 weeks ago my car started needing regular jump starts - up to once a day. I've had the battery and alternator tested and both are fine. I don't see any obvious reasons for the battery to be draining, ie: interior light left on ect. What else could be causing this issue?
Jan 10, 2010 at 5:06 PM
HMAC300
  • 48,601 POSTS
you should have apro look at this. You have a drain on yor battery and it can be a glove box light, hood light, trunk light, the way to test is to take the positive cable off the battery, put a test light between the battery and cable. If it is on then you have a draw whn you find the offending problem the light willgo out. Also if you have something plugged into your cigarette lighter then that can cause it as well...........
Jan 27, 2010 at 5:57 PM
