1991 Buick Lesabre cam shaft magnet location
1991 BUICK LESABRE
102,000 MILES • 6 CYL • FWD • AUTOMATIC
STEELFAN03
  • 5 POSTS
i was just wondering,where is the magnet located for the cam shaft position sensor to read.and if the magnet is gone would that make my car not be able to accelerate rapidly through the range of gears.
Dec 29, 2008 at 7:14 PM
MMPRINCE4000
  • 8,548 POSTS
The camshaft position sensor is a magnet and reacts to a timing point on the camshaft to send info to the ECM with regard to the cams relative position.
However, I would not focus on the CPS unless you are getting an error code pointing to it, in which case it would most likely be the sensor not the camshaft.
I would suspect fuel pressure, ignition, unless you are getting a specific error code.
Dec 30, 2008 at 7:17 AM
STEELFAN03
  • 5 POSTS
im getn a error code of 41.ive changed the crankshaft position sensor,the camshaft position sensor,the coil pack and ignition module.now im just at a loss of what to do.im startn to think the magnet interrupter is gone.and i think thats located on the cam sprocket,let me know if i need to go another route.thanks for the reply.steelfan03
Jan 7, 2009 at 10:08 PM
MMPRINCE4000
  • 8,548 POSTS
I would find a shop that can scan OBDI cars in live data mode. Check the ignition reference pulse.
Also inspect all wiring connections to the ignition for wear/missing insulation. Have the ign. module tested at most autoparts stores for free.
Jan 9, 2009 at 9:27 AM
