1990 Buick Lesabre Hesitation
1990 BUICK LESABRE
101,000 MILES • 6 CYL • FWD • AUTOMATIC
RANJOMAN
My engine runs smooth, no missing when first started and ran for a while. As it comes to temperature, it starts stuttering when trying to accelerate, "missing'.
If I take it out on the highway and run 65mph for a few miles it runs fine, take it back into town, it is back to smooth again. If I drive around town, stop and go, it goes back to hesitating. Seems to run bad when it heats up. Cooling fan works, tried "heat" in the gas tank, checked coolant level. ???
Aug 11, 2010 at 7:56 AM
Hi ranjoman, Welcome to 2carpros and TY for the donation
Start by checking and testing the TPS and MAP sensors and get back with some results we start here
Aug 11, 2010 at 8:18 AM
RANJOMAN
NOT SURE WHAT tps IS, BUT WOULD'T THE CHECK ENGINE LIGHT COME ON FOR A MAP SENSOR FAILUR. ALSO, FORGOT TO MENTION, I REMOVED THE THERMOSTAT
Aug 11, 2010 at 9:24 AM
It'd be nice if the computer tells us all the time when any of the parameter sensors and actuators has a problem but this is not the case, also at times it will pop a code/s and there's nothing wrong with the trouble area. On the thermostat removal it will caused the computer to lock the fuel loop control on open loop and giving it fuel at all times due to the coolant temperature sensor unable to provide the computer the correct input signals to control fuel
Okay the TPS is the throttle position sensor and the MAP is the manifold absolute pressure sensors check and test these 2-sensors and tell me what you got.
Please! explain this and lil bit confused here:
Here's my checklist on what could cause hesitation/bogging/jerking problem:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Aug 11, 2010 at 4:27 PM
RANJOMAN
Could it be a weak alternator? I notice the voltage indicator light
'faintly" illuminated upon start-up. I read that this could be an indicator of a weak alternator. When rpm is high it works stronger?, when rpms are low, weak firing to cylinders?
Aug 12, 2010 at 5:59 AM
Could be the alternator if its not producing the correct output voltages, sensors and actuators needs the correct voltages to operate properly-get it checked out and also check the drive belt tension
Aug 12, 2010 at 3:54 PM
