1985 Buick Lesabre
1985 BUICK LESABRE
PAGGETTK
Brakes problem
1985 Buick Lesabre V8 Two Wheel Drive Automatic
Does anyone know how to remove the reardrum brakes
Apr 10, 2008 at 2:35 PM
BLACKOP555
  • 10,386 POSTS
jack up the back end take off the tires and then try to turn the drum, it should turn freely, if not you will have ot disable the parking brake and turn the starwheel adjuster on the drum to retract the brakes, once it moves freely, spray penetrating oil around the center of the drums and the lugs that way it loosens up the rust, you may have to use a torch and a hammer to get it off, or it might just fall off.
once you got both sides off, tear one down and reassemble looking at the other side as a map, to have a visual guide.
Apr 12, 2008 at 12:59 PM
