1982 Buick Lesabre alternator
1982 BUICK LESABRE
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
SONIA29NASCAR
i would just like to know how to tighten the alternator. i am a girl that dont know much about cars. i broke down the other day and a mechanic told me i needed the alternator tightened because it was bouncing around and loosining the belt also. the whole alternator needs tightning not just the belt. so what do i do
Jan 11, 2010 at 12:16 PM
JDL
  • 16,098 POSTS
Welcome to the forum, there may be two bolts, an adjusting bolt, goes in a slot in a bracket. To adjust belt tension, you pull out on the body of alternator, tighten the adjusting bolt. The belt shouldn't be too tight.
The other bolt is a pivot bolt, may need tightening also. It lets the alternator pivot, while you adjust the tension on the belt. You'll have to use wrenches or socket and rachet, whatever works for you.
I got in a bind, one time in the past, happened to be parked right in front of autostore. Didn't have the proper tools with me. The guys in the store let me borrow tools right off the shelf. Of course the part I replaced, I bought from them.
Jan 11, 2010 at 1:31 PM
