1978 buick lesabre fuel pump replacement help
1978 BUICK LESABRE
DEWBERDOO
i need general help with removal and replacement of the fuel pump. any tips would be much appreciated.
1978 buick lesabre
350 cu.in. 4 barrel
Sep 19, 2007 at 9:01 PM
BUDDYCRAIGG
  • 2,262 POSTS
fuel pump is on the side of the engine, towards the front.
GM was just starting to put different engines in different cars in the mid 70s. So you could have a Chevy 350 in your buick.
If your distributor is on the front of your engine then you have a buick. if it's in the back it could be Olds, Pontiac or Chevy.
changing the pump is pretty straight forwards.
remove lines and hoses.
remove bolts.
remove pump
and put it all back together.
on some engines, like a Chevy, there will be a shaft that keeps sliding down in your way when trying to put the pump lever back in.
good luckk
Dec 12, 2008 at 8:54 PM
