Oil consumption
BUICK LA CROSSE
LARRYB2280
I have a 2005 Buick LaCrosse with slightly over 17,000 miles which I bought new. It is equipped with the 3.8L V6 engine. Since it was new, it has used approximately 1/2 quart of oil per 1000 miles, and I have the oil changed every 3000 miles. I mentioned it at the first oil change, because the low oil level indicator came on. The dealer said that the oil pan was defective, ordered a new one, and replaced it at 4000 miles under warranty. Since there was no evidence of leakage I was sceptical of their diagnosis. The car doesn't leak, or smoke, but it continues to use oil at the same rate, and has done this consistently in the two years that I have driven it.
When I bring this up to the dealer, they want to perform an oil consumption test, which means that I have to bring the car in every 300 miles so they can record the consumption, which would be very inconvenient for me. Trust me, the car loses 1/2 quart of oil every 1000 miles, and I know this for a fact because I have to add a quart 2000 miles after my oil change.
All that being said, how do I get the attention of GM regarding this issue. I have had other GM vehicals with the same engine, and have never had an oil consumption problem. It doesn't make me want to hang on to the car past the warranty period.
May 1, 2007 at 12:58 PM
LSUSSEL
  • 252 POSTS
You can email GM at www.gm.com or get there contact info on their site as well, just a thought, the dealer may be using to cheap of an oil. I have heard of this type of issue before and it was cheap oil.
hope this helps.
May 10, 2007 at 12:16 AM
JAMES ANDERSON
  • 6 POSTS
These 3.8s do seem to have a problem with oil consumption.Ihave personally fixed many of them by,checking the lower intake,if no leaks are visible,then simply replace the PCV valve.These are very inexpensive,like 1-4dollars and generally will fix the oil consumption on the 3.8 engines.If you keep these replaced at regular intervals on these engines it should fix this problems.Try it out and contact me at [email protected] or if you have questions on locating it I will be happy to guide youalso!
Dec 20, 2007 at 10:02 AM
