2006 Buick La Crosse P0411 Error, SAI Incorrect Flow Detect
2006 BUICK LA CROSSE
38,000 MILES • 6 CYL • FWD • AUTOMATIC
RICHAPG
The check engine light came on and the error code read P0411. I reset the code and the next day the error code was back. The car runs good with no noticeable performance issues. I have not found any vacuum hose leaks but I wasn't sure what I was looking for. I'm not sure what to look for and/or test next.
Jun 15, 2008 at 11:39 AM
BRIAN 1
  • 1,030 POSTS
you have to see if the air pump is working first,you have to use a scan tool that can command the air pump on/off to see if it works.a code like this is hard to answer,it code be a number of things,from a blown fuse to a bad relay or a bad air pump,even a blocked hose to the air pump.
Jun 15, 2008 at 7:58 PM
