Whining when accelerating
2005 BUICK LA CROSSE
MHICKS45
Engine Mechanical problem 6 cyl Two Wheel Drive Automatic 55000 miles
What causes a whining noise when accelerating?
This is most noticeable when outside temperatures are lower ... only notice when accelerating.
Candidate diagnoses offered by "know it all" friends are as follows:
(i) idle tensioner pulley is bad ... estimated repair $350
(ii) power steering fluid is low
(iii) power steering pump is bad ... replace
(iv) transmission is going out (don't think this is it ... same noise occurs when in neutral and engine rpm is increased)
What do you think?
Apr 24, 2010 at 2:20 PM
All of these things can make the noise but the most likely problem is the power steering pump. Here is a guide that help you see what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
Sep 11, 2017 at 6:37 PM
FBBLACK
I have a 2014 Lacrosse with 5,000 miles on it. Around 1,500 miles we started noticing a high pitched sound when accelerating. The sound is like a power steering unit bearing going out, but is not. I have taken it to the Buick dealership where it was purchased and they are telling me that this is normal. They also had the Buick rep ride the car and he also said that this was normal. I recently drove a different 2014 Lacrosse and did notice the sound at very low speeds (@5 to 10 miles an hour). The sound that I have is much loader than the 2014 I drove and the noise is consistent up to 30 miles an hour and can be noticed at higher speeds on quiet roads when letting off on the gas.
Sep 11, 2017 at 6:37 PM (Merged)
HMAC300
  • 48,601 POSTS
either take to a different dealer and see wha thtey say if it's normal then it's normal or have a local guy check it out
ANDREA PICKEL
I had the same issue which is why I initially Googled this awhile back. Took my car into my local mechanic and it ended up being my rack and pinion gear box was leaking. Now my car is quiet again! Repair cost on my 2010 Lacrosse total with labor was $884.36.
Feb 26, 2018 at 12:53 PM
Great addition to this thread! Please feel free to help out whenever you are on the site. :)
Feb 26, 2018 at 12:56 PM
2CP-ARCHIVES
  • 4,540 POSTS
My car makes a whining sound like an airplane taking off when I accelerate. It is now starting to make the noise when I coast too. It does not make the noise when I put the car in reverse. It is quite loud all of the time. Any thoughts what could be causing it?
Aug 17, 2018 at 7:23 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
This sounds is created when the transmission filter gets plugged up. Here is a guide to help you see what you are in for when changing it:
Cheers
HLACEFIELD
Thank you! My filter when plugged shifts great no noise, I love this site.
