Low brake fluid indicator
2005 BUICK LA CROSSE
ANDFAM
  • 4 POSTS
Brakes problem
2005 Buick La Crosse 6 cyl Front Wheel Drive Manual 60K miles
The low brake fluid indicator came on. I checked and filled the reservoir. How do I reset the indicator?
Mar 20, 2010 at 10:27 AM
HMAC300
  • 48,601 POSTS
There is no reset only low brake fluid, It is probably because you need front brake pads.
Here is a guide to help you check the pads and fill the brake fluid.
Cheers
Mar 20, 2010 at 1:06 PM
