2005 Buick La Crosse Excessive oil usage
2005 BUICK LA CROSSE
40,000 MILES • 6 CYL • FWD • AUTOMATIC
DREWS
I bought this car new a couple of years ago..everything has been good up till now. I have noticed that my car is using(Burning) a quart of oil for every 1000 miles driven. There seems to be no other problems, it has good gas mileage and good performance. What could be causing the car to burn this oil.
Thanks,
Ken in W. Richland
Jul 16, 2008 at 8:06 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
you may have a faulty oil control ring in one cylinder, if so there will be a whitish Grey deposit building up on a spark plug, pull the plugs and inspect for this first. Start here.
Mark (mhpautos)
Jul 17, 2008 at 1:42 AM
DENNYP
  • 1,824 POSTS
This condition may be caused by the retaining ring on the exhaust valve stem seal not securely holding the seal on the cylinder head boss. If this occurs, the exhaust valve stem seal(s) may move off the cylinder head boss and no longer provide a sealing function between the exhaust valve stem and the valve guide.
You will need to replace the exhaust valve seals if they are not fully seated.
Jul 17, 2008 at 6:18 PM
