Engine Performance problem
1987 Buick Electra 6 cyl Front Wheel Drive Automatic
i am changing spark plug wires(the old ones are off
already)& i don't know which wire goes to which
spot on coil pack(it's distributerless,with one coilpack).
i was told that when on passengerside&facing motor
end with belt&pullies;the left or rear bank starting
with closest plug is 2-4-6 & the right or front bank
starting with closest is 1-3-5.what i need to know is
where each wire goes on coil pack since coilpack is
not marked with a number(i know i've seen some
that are marked&then no problem)the car has been
sitting because at that time it was doing that start&
run&drive fine,then shut off when it wants to&then
start again&drive when it wants to.i need to at least
get wires back on,hope its time to start&drive so i can
get it home to fix the stalling&starting problem(no spark at times&plenty of fuel i think i remember that
was how it was when it stalls&starts whenever.please
i'll appreciate any helpful info for figuring that out.1st
i need 2 get wires on&get it home.thanx,Don
Jan 23, 2010 at 9:03 AM
