Shakes / Vibrations in the front end
BUICK CENTURY
KRAZYCHODE
I have a 1999 Buick Century with a v6 / Automatic and 151,000 miles.
The car starts vibrating and shakes when i accelerate over 45. Recently it gets worse and i cant even drive over 55 without bad steering problems. Also when i go over rough terrain it sounds like the struts or a wheel is going to fall off. Thanks for the help.
Oct 8, 2007 at 12:14 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b6bcfcb165="krazychode"]I have a 1999 Buick Century with a v6 / Automatic and 151,000 miles.
The car starts vibrating and shakes when i accelerate over 45. Recently it gets worse and i cant even drive over 55 without bad steering problems. Also when i go over rough terrain it sounds like the struts or a wheel is going to fall off. Thanks for the help.[/quote:b6bcfcb165]
Check the tires and if ok have them balanced
It may be the shocks but check also the stabilizer rod and links
good luck
let us know
Oct 8, 2007 at 5:39 AM
NNG_2009
[quote:efada34f60="krazychode"]I have a 1999 Buick Century with a v6 / Automatic and 151,000 miles.
The car starts vibrating and shakes when i accelerate over 45. Recently it gets worse and i cant even drive over 55 without bad steering problems. Also when i go over rough terrain it sounds like the struts or a wheel is going to fall off. Thanks for the help.[/quote:efada34f60]
My sister's was doing this, but her's is an 89. He alternator went bad not long after it started doing this. But she just had her tires changed and re-aligned, so maybe you should get that checked.
Nov 15, 2007 at 10:55 PM
