95 buick Century Turn signal does not work
1995 BUICK CENTURY
DEADHEAD58
[b:46fc0b3f16]My turn signals just stopped working. I didn't check the fuses but did check the lights that are with the turn signal fuse, they seem to be working. Is the fuse for the turn signal by itself or as in the book it says the fuse is used with the liscence plate light as well? It has about 85,000 miles on it.
Thanks
Deadhead58[/b:46fc0b3f16]
Aug 11, 2006 at 10:26 AM
MIKEYBDMAN
  • 623 POSTS
[quote:816beecb76="deadhead58"][b:816beecb76]My turn signals just stopped working. I didn't check the fuses but did check the lights that are with the turn signal fuse, they seem to be working. Is the fuse for the turn signal by itself or as in the book it says the fuse is used with the liscence plate light as well? It has about 85,000 miles on it.
Thanks
Deadhead58[/b:816beecb76][/quote:816beecb76]
Ok, if you select a turn signal, and "ALL" of the normal turn lights come on but dont blink, then replace the turn signal flasher. If one of the turn lights is out, replace it and see if they flash then.
I show the back up lights on the same turn signal fuse.
Aug 11, 2006 at 3:42 PM
