85 Buick Century bucking under moderate load
1985 BUICK CENTURY
OAKLEY1
  • 4 POSTS
I have an 85 Buick Century 150,000mi 2.5L TBI with an acceleration problem. Under low to modetare loads it bucks. Even with TCC unpluged. Plugs, wires, cap were replaced. Problem started soon after having ignition module replaced. While power braking and looking at the fuel injector you can see the fuel momentarily stop spraying when it bucks. Where does injector get its reference from? Could it be the ignition module, MAF sensor and if so where is it located?
Apr 18, 2007 at 4:40 PM
[quote:bff878f500="Oakley1"]I have an 85 Buick Century 150,000mi 2.5L TBI with an acceleration problem. Under low to modetare loads it bucks. Even with TCC unpluged. Plugs, wires, cap were replaced. Problem started soon after having ignition module replaced. While power braking and looking at the fuel injector you can see the fuel momentarily stop spraying when it bucks. Where does injector get its reference from? Could it be the ignition module, MAF sensor and if so where is it located?[/quote:bff878f500]
Check the fuel pressure-the computer has to get an ignition signal before it pulses the injectors.
Apr 25, 2007 at 9:08 AM
OAKLEY1
  • 4 POSTS
It was the ignition module. the injectors get their reference from it
Oct 25, 2007 at 12:25 PM
