2004 Buick Century Remote Door Access
2004 BUICK CENTURY
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
BSKATZES
How can I reprogram a remote door lock for my 2004 Buick Century?
Feb 28, 2010 at 9:06 AM
FACTORYJACK
  • 4,159 POSTS
If your talking about a transmitter, you need a scan tool to reprogram it.
Feb 28, 2010 at 11:25 AM
BSKATZES
The “scan tool” seems to be an optional method and possibly an easier method to reprogram remotes. There are a variety of sequences for different cars that allow for a non-tool reprogramming.
In the case of the 2005 Buick Century it involves inserting the key three times while holding the door unlock, then releasing the unlock followed by holding the remote lock and unlock buttons for 12 seconds – repeat last step up to four remotes. All intended remotes must be reprogrammed.
Reading some of the responses’ to this and other questions it also seems that there are “take it to the dealer” replies that may have the motive to discourage people from working on their own vehicles.
Mar 5, 2010 at 7:14 AM
FACTORYJACK
  • 4,159 POSTS
Did any of these methods work? Here is the information that I got for your vehicle.
Service Information
2004 Buick Century | Century, Regal ( VIN W) Service Manual | Document ID: 682874
Remote Control Door Lock Transmitter Programming
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Install a scan tool.
Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs.
Press the START soft key on the scan tool.
Important: The scan tool must stay connected until all of the transmitters are programmed.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.
Repeat the previous step in order to program up to 4 transmitters.
Remove the scan tool.
Operate the transmitter functions in order to verify correct system operation.
Mar 5, 2010 at 8:44 AM
FACTORYJACK
  • 4,159 POSTS
This is the information from ALLDATA on a 2004 century, it looks as though it is taken from the pages of GM service info.
TRANSMITTER PROGRAMMING
IMPORTANT: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Turn ON the ignition, with the engine OFF.
Use the scan tool in order to access the Body Control Module (BCM) Special Function: Program Key Fobs.
Press the START soft key on the scan tool. IMPORTANT: The scan tool must stay connected until all of the transmitters are programmed.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds , the locks will cycle in order to confirm the programming of that transmitter.
This is the ALLDATA info for a 2005 Buick Century
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds , the scan tool will indicate that the transmitter is programmed. IMPORTANT: The scan tool must stay connected until all of the transmitters are programmed.
As you can see from my point, it is not meant to discourage you from performing your own repairs. There are some things that you may not be able to perform, and that is becoming more of the standard of operations as time goes by. A locksmith may have a different procedure that works, it is there perrogative to find alternate methods for them to remain competitive. I can only offer the information that I am provided.
Mar 5, 2010 at 9:54 AM
