cooling system service instructions please?
2004 BUICK CENTURY
ANSELMOGARCIA
I need to do a coolant flush on the car, it keeps overheating.
Feb 21, 2010 at 8:35 AM
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
This video shows the job being done on a similar car but the process is the same.
https://youtu.be/5ayVixLqS4E
Mar 3, 2010 at 1:15 PM
TIMZONE157
How do I drain my radiator to put fresh anti freeze in.
May 26, 2021 at 12:21 PM (Merged)
The drain plug is on the lower left tank of the radiator here is a guide and a diagram (below) to help you see what to do.
I prefer to pull off the lower radiator hose. Drains a lot faster. To drain the block you should remove the block plugs on them if possible. If not just ad water and run it through the system. And re-drain and refill with proper coolant.
IGGYSBUICK
Could you please tell me where the radiator drain is located on my 2000 century. thanks so much
iggy
IMPALASS
  • 3,112 POSTS
Hello It should be located at the lower drivers side of the radiator.
https://www.2carpros.com/forum/automotive_pictures/248015_84980747_1.gif
Hope this helps
D FURMAN
Where is the drain for the Radiator. or does it have one?
It should be on the lower driver's side. It will look like a wing nut. If there isn't one, you may have to remove the lower radiator hose to drain the system.
