2004 Buick Century Gas Odor
2004 BUICK CENTURY
BC1972
Smells problem
2004 Buick Century 6 cyl 80000 miles
When starting my vehicle for the first time, usually in the morning, I am getting a strong odor of gas inside the car. What could be causing it? Thx
Jan 2, 2010 at 7:29 AM
ERNEST CLARK
  • 1,730 POSTS
You could have a leaking fuel line. You should definitely check all the lines that run from your fuel pump in the trunk all the way to your motor. Don't forget that there are lines that send fuel to the engine, as well as a line that sends excess fuel back to the gas tank.
Also, it's possible that your engine is running a little rich during start up, and what you're smelling is just unburned fuel coming out of the tail pipe.
If you must turn your engine over quite a few times on a cold start up before it actually starts, then that's what it is. The smell is just penetrating the cabin.
But fuel vapor is a very dangerous issue. Check everything thoroughly. You could very well pass out inside of your car if you're breathing that in for a lengthy amount of time!!!
Jan 9, 2010 at 1:09 PM
