when you first turn on your key, you should hear the pump run for 3-5 seconds.
it's a hum sound coming from the fuel tank.
turn the key to the ON position and listen for the pump.
after it stops, turn your key back off
wait 10 to 15 seconds and turn you key back to ON.
repeat this about 10 times.
that will prime the fuel lines.
if you car still will not run then you need to do a fuel pressure test.
the fuel pump need the gas flowing through it to keep it lubricated and cool.
the pump may have destroyed itself when you ran out of gas.
good luck
Dec 12, 2008 at 3:13 PM
