The headlights go off when the high beams are activated. The only way to keep the headlights and the high beams on is to hold the switch. If you let the multi function switch go, you lose all lights on the vehicle. We have replaced the multi function switch, but it has not corrected the problem. Do you think it could be the headlight relay switch. Thank you, looking forward to hearing for you. Sincerely ALex.
Nov 9, 2008 at 1:33 PM
