2000 Buick Century illumination of odometer and gear indica
2000 BUICK CENTURY
118,000 MILES • 6 CYL • FWD • AUTOMATIC
PAUL BRANNON
The illumination of the odometer and the gear indicator is weak or non existent. I have check the fusing and found it to be OK. At times the illumination was weak and then faded. What else should I check?
Jul 3, 2010 at 6:27 PM
RICHZOMBIE
  • 173 POSTS
Check the grounding at the rear of the instrument cluster and also check the bulbs.
Jul 5, 2010 at 12:35 AM
EDWARD.S
  • 166 POSTS
Hi,I've Run Into This A FewTimes now.You Can't Replace Anything .It Is a Florescent display. You have To Remove The Cluster And Send it out for Repair.At the speedometer Shop.
Hope this helps you,
Good luck
Edward S.
Jul 19, 2010 at 7:48 PM
