2000 Buick Century gasoline leak
2000 BUICK CENTURY
GRAHAMCOX
Smells problem
2000 Buick Century 6 cyl Front Wheel Drive Automatic
The top of the motor has a single unit, similar in size and shape as the PCV valve, with a plastic tube going into the top and a metal tube out from the bottom (threaded) and it is leaking gasoline. What is this part called and is it easy to replace? It looks like some sort of filter.
Thanks.
Feb 24, 2010 at 11:54 AM
TWINSRAM
  • 42 POSTS
The only thing I can think is the carburator. If your car has fuel injection, it can only be an injector. Those are the only two thins that would be on top of the motor and be leaking gas. Replace the line or the part
Feb 26, 2010 at 3:51 PM
