Reverse lights not working?
1999 BUICK CENTURY
80,000 MILES • 6 CYL • FWD • AUTOMATIC
MM5129
which fuse controls the back up lights ?
Nov 13, 2008 at 1:12 PM
Hi:
H 7 - 8 TAILLAMPS 15A fuse
This is a bit of a educated guess, but that's what Im reading here.
Let me know if this was accurate. If not, I'll try again.
May 21, 2021 at 3:30 PM
MM5129
It's in the fuse box under the hood on the passenger's side. In the 1999 Buick Century Manual it's called the "rear compartment release" fuse. Well, on that year and model Buick, there is no "rear compartment release" fuse. There's a 7.5 amp back-up light fuse in it's place. There are two 7.5 amp fuses in the fuse box under the hood on the passenger's side; check both fuses if your unsure of it's exact location. One of them will be blown and it will be that one that controls the back-up lights. It took me a long time to figure this out. Thanks for trying to help Joe.
Hi:
I'm glad you got it figured out. I was looking through repair manuals and gave you the best I could figure. Thanks for the info. It will most likely help someone else in the future.
