New Alt. Battery good and tested. Battery connections clean. Car starts and runs foir a bit then stalls. If I turn on the lights, rear window defroster, turn signals, the engine stops. I have 5 volts at a 3 wire sensor under the hood. !4 volts when engine is running and 11.6 with engine off. Ignition mod good and tested, coils good. I checked for voltage drop in fuse box. Car stalls when ever I turn on lights or the such and with engine off I have voltage drop. I checked the row D of the interior fuse panel.
Help
Help
Jan 15, 2010 at 7:19 PM
