1998 Buick Century fuel pump
1998 BUICK CENTURY
TEMARSHALL
1998 Buick Century 4 cyl Automatic 180000 miles
i just leased a 1998 buick century. had it about 2 weeks now. when i test drove it was as quiet as a whistle but sometimes it took multiple cranks to get it started. so they replace the fuel pump and filter. sometimes when i crank up the car it vibrates and you can here the pump pumping but if you shift into gear before it stops making that pumping noise the car cuts off. now its making a humming noise whenever you turn the wheel. what could this or why could this be?
Nov 10, 2008 at 9:17 PM
Hi:
I think you need to have the fuel pressure regulator checked. It sounds like the pump can't keep up with what is allowed to flow, and as a result, the engine can't burn all of the fuel.
As far as the steering noise, check the power steering fluid. It sounds like it's low.
Nov 12, 2008 at 6:33 PM
