1998 Buick Century Don't works regulator of heating venilat
1998 BUICK CENTURY
80,000 MILES • 6 CYL • FWD • AUTOMATIC
BALAGANOV
Please help me to check regulator of heating ventilator. couple weeks before this regulator stopped turn on in slow RPM and work on for max RPM only. Today this regulator stoped turn on in any position.
Does it connect to regulator himselve or to soma electrical fuses?
How I can check where is the problem
Dec 11, 2008 at 5:11 PM
JALOPYPAPA
  • 467 POSTS
It sounds like you're talking about the heater fan and controls. If only the high speed works, the problem most likely is with the electrical resistors, which are on a cover plate bolted to the front of the heater box under the hood, near the fan. But if no speed works, the problem is most likely the fan itself. If you have a circuit tester, you can see if voltage is reaching the fan leads.
Dec 13, 2008 at 8:36 AM
