The fuse I am blowing is a 15A that says it is feeding the tail lights and lic plate light, however when the fuse blows it also takes out the interior dash or cluster lights.This was my moms car , when I got the car the lights where out . so I took it to service guy that use to work for a buick dealership. He replaced the light or dimmer switch and put in a new 15A fuse . It worked well for 6 months. Now when the 15A fuse blows and I replace it ,it will work for about 5 minutes (keep in mind this is happening when all the lights are running at night.) When I go to install a new fuse just after it blows it will not hold at all and blow right away. Could I have another bad dimmer switch? Do they make more than 1 dimmer switch for this car? Should I try a 20 Amp fuse ? Help Bruce G
Sep 5, 2010 at 12:15 PM
