1994 Buick Century Replacing turn signal/brake lights in re
1994 BUICK CENTURY
DKIBBLES
Electrical problem
1994 Buick Century 6 cyl Two Wheel Drive Automatic
What is the best way to go about changing lights in the rear of a 1994 Buick Century? Looks like the only way I can see is to take the entire rear lens assembly apart, but I was hoping there might be an easier way.
Jan 7, 2010 at 8:14 PM
ERNEST CLARK
  • 1,730 POSTS
You do NOT have to take the entire assembly out. In the trunk, pull the carpet back right behind your lights. There may be a couple plastic screw to remove first. You'll see the wires to the bulbs. Just unclip the connectors and twist the whole plastic retaining ring and pull the light bulbs out.
Jan 9, 2010 at 12:55 PM
