1994 Buick Century HOW TO DISSAMBLE THE STERRING COLUMN
1994 BUICK CENTURY
JOE8751
Steering problem
1994 Buick Century 6 cyl Front Wheel Drive Automatic
HOW DO YOU DISSAMBLE THE STERRING COLUMN TO REACH THE IGNITION SWITCH
Jul 8, 2009 at 3:49 PM
LOUT5369
  • 217 POSTS
The ignition switch is located on top of the steering column,remove the panel under the column,you will see a saddle clamp with 2 studs 1 on each side of the column,remove the nutsremove gear indicator cable,lower the column,the switch is on top of the column,the high beam switch is located below the ignition switch,using a 5/16 or 8mm wrench, remove the screws on high beam switch,then remove ignition switch,to install reverse procedure. Hope this helps,Lou
Jul 21, 2009 at 9:08 AM
