I see two white tubular-type switches on a metal bracket with spring loaded pins pushing against the brake pedal lever. I'm guessing one is CC and the other is the brake light control.
My CC used to work. One day my brake lights stayed on after the car was turned off causing the battery to die overnight. A semi-knowledgeable friend resolved the problem by doing something around the brake pedal, however, the CC has not worked since. Not sure what he did.
One of the tubular-type switches has two male electrical plugs; one has an electrical plug on it the other does not. If this is the CC is there a missing female plug that belongs on it? I've looked but do not see another plug. The second tubular-type switch, above the first one, has only one electrical plug (brake light switch??) Will replacing the first switch (CC?) make the CC work? What will fix this problem? Thanks!
Jul 1, 2008 at 1:01 PM
