OK new news i flushed the system and bam i got heat but only for like 1 hour then i puled over and popped the cap and wouldn't you know it was foaming like a rabid dog turns out a guy told me when he seen it that i need to do a chem flush and a major one at that i hope this helps any ideas on this oh and yes the fluid that came out was brown when i flushed it but i put new green in it plus i believe he might be right because on the way back home when i floored it i had heat but at normal speeds not so much not cold but close
one more thing i had to Frankenstein the flush because the drain plug would not allow anything through i even pulled it all the way out I believe
there is sludge in the system someone put red antifreeze in it before i owned it looked really bad
and the electric cooling fan keeps coming on like riht when you turn on the key and then off then back on then on for a long time then off,on,off,on could the sludge be causing the censer to fail or do i need to look at the relay
Nov 19, 2008 at 10:48 PM
