I have hopefully narrowed the problem down the the idle motor. I have been looking for the ecm harness ground with no success. Any help?
Jun 25, 2008 at 8:51 PM
CERTIFIED EXPERT
What you have is not a an idle motor-its called idle air control valve-check for foreign material in the IACV bore that might causing your rough idle -if this the case-
Jun 25, 2008 at 9:20 PM
LMJ
MEMBER
it either won't idle, idles fine, or idles about 5 grand
