1993 Buick Century fuel injection
1993 BUICK CENTURY
62,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHINN
My father's biuck was run out of gasoline and has been giving us trouble ever since.
The filter has been changed, the fuel pressure has been tested at approx. 45 lbs. and there is good fuel flow when I take loose the fuel line at the filter near the tank.
I fear I may have to replace the injectors at a price I would rather not pay. Do you have any suggestions what to check before I replace them?
Thank you
Kevin
Nov 28, 2009 at 11:40 AM
HMAC300
  • 48,601 POSTS
your fuel pressure seems to be good, you might want to contact a pro near you and see what he says. He might be able to put injector cleaner in it to get it running then you migh tbe ok. It may be the cheapest way to go.
Dec 2, 2009 at 12:39 PM
