1990 Buick Century 1990 Buick century
1990 BUICK CENTURY
163,000 MILES • 6 CYL • FWD • AUTOMATIC
SGTMAJOR
  • 17 POSTS
Car stalls while driving after about 30 to 45 mins.If you switch to neutral before stall,it won't stall but as soon as its put into gear(forward or reverse) it will stall.It starts right back up,every time.Just before the stall there is a heavy vibration,like if you were going over a rumble strip,then it stalls.I was told it may be a max airflow sensor,but I wanted to know for sure or atleast get several opinions.The max airflow sensor is kind of expensive,otherwise the car runs like new.I bet it has another 100 to 200,000 miles left in her.
Thank You,
SgtMajor Cassidy
(USMC-Retired)
This was the reply:Posted at Fri Jul 25, 2008 4:16 pm
By mastertechtim, Tech level 9
(268) Give Feedback | Votes: 18
ues sir she still has plenty of life left in her. your problem is a sticking torque convertger clutch solenoid in the transmission. if you look down at the transmission from the top you will see a white electrical plug toward the radiator side. unplug this electrical connector and your problem will be gone. you can drive forever with it unplugged and wont harm transsmission or you can have the solenoid replaced and keep the torque converter lock up. (its basically a 4th gear in the transmission) you dont have to have it. most people just leave it unplugged. i would replace it if it were me because im *bad word* about my cars. the cost to repair can range from $50, if you do it yourself to about 300 if yiou take it to a shop. hope this helps.
_________________
thanks for using 2carpros.com
I looked everywhere I couldn't find any white wire coming from the front of the tranny.Can you be more specific?Drivers side or pass side?Is wire on top or underneath?I didn't see any wires that have a connector on or coming from the tranny.I even pulled both front tires,but didn't see it.Thank You for all your help,any further assistance would be greatly appreciated.
Jul 28, 2008 at 10:33 AM
JALOPYPAPA
  • 467 POSTS
I believe it's going to be near the cover plate on the side of the transmission, on the driver's side.
Aug 4, 2008 at 12:27 PM
JALOPYPAPA
  • 467 POSTS
But the solenoid itself is inside the transmission. I'd get someone with some experience or take it to a shop.
Aug 4, 2008 at 12:28 PM
SGTMAJOR
  • 17 POSTS
[quote:53f7a840ee="jalopypapa"]I believe it's going to be near the cover plate on the side of the transmission, on the driver's side.[/quote:53f7a840ee]
Thank You,I found it and disconnected it.
Thanks again for all your help!!!!!
SGTMAJOR
Aug 5, 2008 at 7:38 AM
SGTMAJOR
  • 17 POSTS
[quote="sgtmajor"]Transmission problem
1990 Buick Century 6 cyl Front Wheel Drive Automatic 163000 miles
_________________
THANK YOU TIM
I did what you said,and so far, problem solved.
I'm sure this isn't the right place to leave your comments however,I had to say Thank You!!
Aug 5, 2008 at 7:43 AM
