1. On some models you will need to remove the headlight bezel mounting screws and the bezel
2. Remove the mounting screws for the lamp assembly
Remove the mounting screws securing the lamp assembly
3. After the screws are removed, pull the assembly from the vehicle
Pull assembly from vehicle
4. Disconnect the twist lock socket from the lens housing
Disconnect twist lock
5. Remove bulb and replace
Newer models have the turn signal separate from the headlight assembly.
Hope this helps, have a Great New Year's :D
May 21, 2021 at 3:31 PM
