1989 Buick Century tps switch
1989 BUICK CENTURY
94,400 MILES • 6 CYL • FWD • AUTOMATIC
UNCLEJAI
where is my tps switch so i can replace it?
Sep 26, 2008 at 10:27 AM
JDL
  • 16,098 POSTS
I'm not sure the picture worked. The tps should be located on the throttle shaft at the throttle-body. Three wire connector. Have you tested it or anything?
https://www.2carpros.com/forum/automotive_pictures/170934_tps_1.jpg
Sep 26, 2008 at 10:49 AM
KINKER
  • 4 POSTS
IT is under the throttle body it is a lot easier to replace if you remove the throttle body itself . a little more work maybe but a lot easier
Feb 4, 2009 at 8:44 AM
